Turn signal flasher for LED's '06 Elantra?
redhelmet13
4 nm se KNFW
Anyone know where I can get an LED turn signal flasher for an '06 Hyundai Elantra? Better yet, what is the part # of the old fashioned flasher module? I am lookingt to replace the turn signals and brake light bulbs with LED's (Found a website that has the bulbs bu not the flasher module for LED's). You cant just switch from bulbs to LED's when it comes to the turn signals due to the lower current draw from the LED's...
Ed
ka8ypy
Depends on the LED module, it has nothing to do with current draw, it has to do with voltage. As long as the LED bulb is 12VDc then it should be a straight swap. In 5+ years of doing emergency lighting installs, I have never seen an issue with the LED replacement bulbs as a straight swap.
