Tuscarawas County Ohio
copper1453
NE Ohio
I am looking to purchase a scanner to pick up all of Tuscarawas County and possibly the surrounding counties. I know they also have the Ohio MARCS system.
Which scanner would be the best for this area?
Thank you for all of the feed back...
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
The best scanner is almost always the best one you can afford.
Uniden BCD396XT / BCD996XT / BCD436HP / BCD536HP. Those models will all work well around here. Also GRE PSR-500 / PSR-600 or Radio Shack PRO-197 / PRO-106.
Problem with the GRE / RS models is that I don't how available they are, or if you can get any support for them. So at this time, I can only recommend Unidens.
Any of the Unidens that I mentioned above will monitor all of the popular systems in your area. However, only the BCD436HP / BCD536HP will monitor P25 Phase 2. Currently there is nothing in your area using P25 Phase 2. However, MARCS-IP is being built out currently and will likely eventually have PHase 2 talkgroups.
So I'd recommend getting a Uniden BCD436HP or BCD536HP. Bite the bullet. You won't need another scanner for many years if you get one of those.
Mike
