I found this from an older post:
Turn on the unit while holding the HOLD/RESUME Key.
After the Start Up Screen and unit starts to scan, do the following:
Press and release the F-Knob and the Volume Control at the same time.
This should take less than two seconds. The lower portion of the display should change and will look something like this:
AGC=2 VOL=-37
ANA RES TIME:0
Turn the F-Knob to a setting you prefer. This is the Response Time, or how fast the audio level is adjusted. After the adjustment, Press and HOLD the F-KNOB, then turn the knob to the next adjustment. The display will look someting like this:
AGC=2 VOL=-37
ANA REF GAIN:0
This is how high the Volume Level will adjust to. Turn the F-Knob to make adjustment to a level of your preference.
