Twelve F-15E Strike Eagles,Seymour Johnson Air Force Base
milcom_chaser
We have Twelve F-15E Strike Eagles from Seymour Johnson Air Force Base, N.C visiting here in Arizona!
Would so appreciate any Air/Air Squad freqs for them. They are out here doing extensive training.
Thanks again.
BM82557
Berkeley Co WV
You could try these, don't know if they are still current -
Seymour Johnson AFB, NC
(4th FW, F-15E), (77th ARS/916th ARW, KC-135R)
PTD: 134.9, 372.2
Tower: 126.25, 370.875
Approach/Departure: 119.7, 123.7, 273.6, 290.9, 338.6
Metro: 323.925
GCA: 253.6, 326.2
Ground Control: 275.8
4th FW (333 FS, 334 FS, 335 FS, 336 FS) (F-15E)
Callsigns: ADLER (09), ALOFT, ARCHER (09), BARLEY, BLACK, BURNER, BUTLER (09), CAESAR (08), CANDOR (09), CANOE (09), CARSON (09), CHEETAH (09), CHICO (08), CIDER (07), CREEK (09), DIME, FANGO, GOATEE (10), GRUMPY (09), JACKAL (10), KIOWA (09), METEOR (09), MINT (10), OLDS (09), PIKE, RAVAGE, RED DOG, RINGO (09), RUCKUS (09), RUMMY, SABER, SCUD (08), SLEDGE (07), TORCH, TRICKY (08), VEDA (09), WACO (10), WAPPO (09), ZESTY (09)
Command Post (RAYMOND 25): 381.3
4 FW CP: 311.0, 321.0
4 FW SOF: 376.1
4 FW Air-Air: 300.325, 300.625 (10), 300.725 (10), 300.825, 301.025 (10), 354.2, 377.85
333 FS "LANCERS"
Callsign: ARGUS (11), BURGER, CADET, CRAB (08), DUSTY, GATES (11), INCH, LANCER (11), MITT, MOSS (11), SAWS, TEAK (11)
333 FS Air-Air: 300.125 (10), 300.225 (11), 300.525, 300.625, 300.725, 300.925, 301.025 (10), 301.125 (11), 301.325 (11), 301.425 (11), 333.1, 333.4, 333.5
334 FS "EAGLES"
Callsign: EAGLE (10)
334 FS Air-Air: 300.825, 383.3
335 FS "CHIEFS"
WIGWAM OPS: 298.6
Callsigns: ARROW, CHIEF (11), HOAX (09), KONG (10), MOHAWK (11)
335 FS Air-Air: 252.525 (11), 300.125, 300.525 (09), 300.725 (09), 300.925 (09), 301.225, 301.525, 335.1, 335.2, 335.3, 335.4, 335.9, 336.225, 337.85
336 FS "ROCKETEERS"
Callsigns: CARVER, GUNDOG (10), INTERN, MAGNET (10), PLAYER, RAMROD (11), ROCKET (11)
336 FS Air-Air: 252.525, 300.125, 300.925, 301.225, 336.4, 336.9
spacellamaman
everything already mentioned is probably all you need but my .02 is, that which i can confirm is, search 300-302, specifically 300.025 (301.025?) iirc was used by some F-15s in a NASCAR flyover last year, a2a, and then refered to switching to 260.1 which i have since hear active using kgsb assc. callsigns. have fun, if you see them more than once youll beat my count :)
FLANO
AZ DB Administrator
SE of Tucson, AZ
They will be using the SNOWBIRD frequencies for interplane - mainly, while here at DMAFB.
They will be on the RANGE/MOA frequencies as they play at the different areas in AZ.
Callsigns include, Breeze, Sleet, Ice, Snow - all winter weather related :)
