BCD436HP/BCD536HP: Two 436hps and one Old style Uniden GPS Puck
AC0RV
Park Hills, MO
Can I use the same Uniden GPS Puck to feed two 436hps and other than a spliter, what do I need to get ?
Thanks.
phask
zanesville
I know it can be done, the fact is the NEMA signal can service multiple devices. As to how - no idea. (Lot of help )
Some HAMS run APRS and multiple radios from one GPS.
AC0RV
Park Hills, MO
I am trying to figure out if the original Uniden GPS Puck, if can feed to at least 2 436hps. Also how to do so ?
AC7FD
Meridian, ID
All the GPS puck does is send the position data to the radio. It shouldn‘t be a problem to split that to two radios. You would need to make an adapter….
AC0RV
Park Hills, MO
Greetings and good news. Using a DB9 Y Connector, I was able to connect the two 436hps.
Thanks for all the help.
So Mr Moderator. Please close this thread.
AC0RV
Park Hills, MO
No, But it can be done by using a DB9 Y cable. Connect the y to the Db connector on the Pluck.
Then you can use two cables.
