Two antennas
keithbias1
Liberty, Indiana
Is it possible to somehow tie two antennas together into one scanner. So if I want to monitor two different frequencies I can use two different antennas on one scanner?
jonwienke
More Info Coming Soon!
VA
Do a google search on "diplexer" and select one that has the frequency split and connectors you need.
ka3aaa
middletown, pa.
just get a tri band scanner antenna and be done with it. Most scanner antennas are broad band and will work just fine. There is no need for multiple single banded antennas and trying to figure out how to connect them all together for a scanner.
