Backwards splitter??????????????????????????????????????????
What exactly is a backwards splitter?
A splitter is a splitter. No matter if it is sideways, diagonal, frontways, slant ways, backwards, etc. A splitter is also a combiner as it is bi-directional.
I can find NO manufactuer of mutlicouplers who advocates the use of their product in a manner in which you describe.
An active multicoupler is nothing more than a preamp and a splitter. Possibly a band pass filter and Bias Tee as well. A passive preamp is just a splitter (both designs incorporate a design to provide better isolation between ports).
Can you provide me with a schematic of a multicoupler that effectively does what you intend it to do??
"Receiver only" mulitcouplers (as there are some transciever multicouplers that are very complex out there) are meant only to split (and amply in active ones) the signal for multiple receivers using ONE antenna and prevent receiver interaction. Again, I can find no reference other than in these forums, of a use other than those prescribed by the manufactuers of these products.
I bring this up, because I do not want to see someone spend 80 plus dollars on a piece of equipment to use it in a fashion that would best be served by buying a much less expensive and way more approriate diplexer. Or if they can live with the signal loss, and antenna interaction, a 3 dollar splitter.
Does anyone have any scientific proof that a mulitcoupler can be used as a "backwards splitter", i.e. test equipment results from a spectrum analyzer and/or signal generator? In addition any block diagrams and schematics to back this up? I don't have any proof that it wouldn't work well, simply because I never would have thought of using a multicoupler (a glorified splitter) in such an application as opposed to a diplexer (which works very well).
Thanks in advance,
Ryan
