Two different p25 systems on same radio?
medic29
Champaign, IL
In our area we have two different p25 systems. We routinely work with another agency on the other system. Is it possible to have both systems installed on our radios? Then we can just switch to the talkgroup we need when needing to talk to the other agency.
Sent from my SAMSUNG-SM-G930A using Tapatalk
buddrousa
That should not be a problem you should go through the other system administrator to get you radio programmed just as the other agency would have to go through your system administrator to get their radios programmed. As long as both system administrators are happy most radios will work like you ask. I just do not think you can scan both at the same time just one system or the other.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Do they both use the same frequency band? If not, you'll need multi-band radios. Beacoup dinero.
Are they both the same Phase? Depending on what phase your radios can handle, there may be issues.
You really need to lay some specifics about both systems on the table here if you want useful answers. Without that, any answers you get here are just speculation or WAG's (wild *** guesses.)
j0sh
Steve is right, specifics will help answer your question. However, FYI - we have multi-band radios that work between Harris and Motorola P25 systems and it works great. We just change zones/systems depending on what system we need to access.
medic29
Champaign, IL
Our system is phase 1,the other system is statewide and up north they have some sites that are have upgraded to phase 2 but the sites all around us are still operating on phase 1.they are operating on the 8 00 frequency band as is our system. Our dispatch has the capability to patch both systems but rarely does.
Does this help?
medic29
Champaign, IL
Yeah, we know we would have to have permission from the system admin. We are trying to get away from having to carry 2 radios at an incident.
SteveC0625
Does this help?
The best thing to do is have your system admin and their system admin sort this out. They know what's required, and what radios in your inventory can do what you want. This really is a situation that needs to be handled by management of both agencies.
medic29
Champaign, IL
My question is more of information gathering. The systems have multiple agencies, mine is just one on there. We are trying to understand the possibility before we involve the red tape and power struggles of those who like to throw their power around and give the one jerk reaction of no, we can't do that.
I'm trying to gain information from those with knowledge. Once we have the information, then if we decide to move forward we will approach those in the system administration of both systems to see if they agree and to gain the needed permissions and our approval.
medic29
Champaign, IL
This isn't giving me any information. The system Admins aren't going to know off the top of their heads what equipment we have etc. Plus they aren't going to want to waste their time fielding questions. Our system admin is more worried about obtaining more money to upgrade his equipment, etc. Our requests are low priority. Thus the reason we are looking elsewhere to gain this knowledge. But thanks for the advice.
buddrousa
Glad to see you do the ground work before starting the working together process like I stated aslong as the radios will work and aslong as the admins are happy it will make the job better for all.
hitechRadio
The ops original question. To keep it simple!
Yes you can have multiple systems
And you can scan them (Multi-System Scan) however you will not have priority scanning, you can even add in conventional in the mix to scan.
We do not allow Multi-System scan due to no priority.
Side note: To bad the systems are not tied together, Like Interzone (more Involved) or ISSI8000, but that would make sense.
Out of curiosity what systems are you talking about?
medic29
Champaign, IL
PM Sent
evfd1625
Indiana
Based on where you are from, if it's Starcom and MDICE, if allowed you can have both systems programmed in one radio. Any radio capable of doing one can do the other as they are both 800 and P25. If using a phase one radio you will be limited to the phase 1 talkgroups on Starcom, which shouldn't be a problem there. However, Starcom charges a subscriber fee, which may or may not be an issue for your agency.
medic29
Champaign, IL
Starcomm is said to waive any fees if the access is only used in emergency, mutual aid situations.
evfd1625
Indiana
That's good, when I lived in southern IL our fire department was so paranoid about user fees the radios were locked up forever.
medic29
Champaign, IL
A few months ago those who were not paying the fees had to turn the radios back in. Those radios didn't have the talk groups in them that we are talking about though.
wa8pyr
Technischer Guru
Lead Database Admin
Ohio
It's easily done, even on a fairly basic radio (as long as all the systems are 700/800). Multiple bands merely means a more expensive radio. We do this here in my area on a daily basis; our current template has five different P25 systems and everything works just fine.
It shouldn't matter that some sites of one system are Phase I and others are Phase II; in a mixed mode situation like that it's probable that the Phase II sites can revert a talkgroup back to Phase I if a radio not capable of Phase II affiliates. Alternatively, the system administrator of the other system can arrange the settings in the system so that the radio IDs for your agency are limited to Phase I sites only.
So in a nutshell, it's easily done from a technical standpoint; whether the system administrators are willing to make it happen is another matter (I'd find it unusual if they did not want to make it happen).
