Two programming questions for TK-8180
uuacallis
I am using the Kenwood TK-8180 in a STM-32 DVM MMDVM Hotspot for my DMR Ham Radio.
I have two challenges that I cannot seem to figure out and hoping you guys that use KPG-89d a lot more than I will know.
1) How can I disable the front speaker when the Aux Port is in Use - Everytime my hand held is connecting to the hostpot I hear the DMR Noise on the speaker despite that the Aux cable is hooked up.
2) How can I allow the transmitter cycle to go longer. Sometimes these guys on the rag chew keep talking for upwards of 90 seconds before they take a breath. The problem with that is that at around 60 seconds the radio makes a loud noise and won't stop.
thanks in advance,
Adam
ohiohonda
1) You may be able to program a Public Address (PA) button to mute the speaker from receiving audio. I have not used this before and it may not allow the radio to receive traffic for your hotspot while enabled but its worth a try.
2) Increase the TOT ( time out timer). This feature is within the Zone edit tab. Default is set for 60 seconds.
uuacallis
Thanks, the TOT fixed that issue and I figured out how to set min volume to 0 so I can turn it down.
Two last issues I am hoping you guys may be able to help with -
It seems that if I program the channel for Narrow frequency my DMR radio cannot decode the transmission (despite being set for 12.5khz), if I set it to wide it works.
For HAM I guess I don’t much care, I can use 25khz channel, however I also am trying to work on a business itinerant frequency for work that we must be on narrow per our license. Any ideas why that would happen on the TK-8180:K model ?
Second issue is one of my TK-8180s has the special firmware and cannot be programmed with KPG89d. I am trying to figure out how to reflash it so I have one programming software vs two.
ohiohonda
Without knowing how the hotspot interfaces with the radio it is difficult to determine what would be causing the narrow/wide band difference. I assume that you modified the settings in the radio software to accommodate interfacing the hotspot to the DB25 connector in the rear of the radio. You could trying and set the mic sense to high within the programming software (Extended functions>Aux>Mic Sense).
The firmware is changed by the program called Fpro. This software is installed in the same location that the .exe file is for the programming software. You will need to locate a firmware compatible with the radio. Launch the Fpro software and point the software to the firmware on your computer. The radio will need to be set in firmware program mode before it will except the new firmware. Hold the S key while powering the radio on will set it for firmware program mode. Be careful with loading new firmware because this is a easy way to make the radio a paper weight.
