two scanners on one antenna????
mountain777
Is there a way I can run two scanners off one antenna.Not both at the same time.Only one at a time.
Chris-M
Yes..
Yes you can run as many scanners as you want (receivers). You cannot run multiple transmitters at the same time unless you have a switch in the feedline.
I'm using a coax 'Tee' in my discone feedline. Receiving on an old RS PRO-2004 and my PRO-2053.
http://images.google.com/images?hl=en&lr=&q=coax+T&btnG=Search
Here are some coax switches. You don't need one if you are only using a scanner or multiple scanners (receive only).
http://images.google.com/images?hl=en&lr=&q=coax+switch&btnG=Search
Voyager
Re: Yes..
There is a caveat, however. You will lose 3dB with each tee.
The proper way to do it is with a device such as the Stridsberg multicoupler: http://www.stridsberg.com/prod01.htm
But, if you can live with 3dB per split, that's fine, too. You could have some interaction between the receivers, however.
Joe M.
N
N_Jay
Guest
Re: Yes..
What?
You have never heard of a transmit combiner?
Cavity or Hybrid???
W4KRR
Coconut Creek
Um, of course. Just hook up the antenna to the scanner that you want to listen to. Then, you can disconnect the antenna and hook it up to another scanner. In fact, you could run thousands of scanners this way, one at a time, to one antenna! :eek:
STiMULi
Tucson, Arizona
OR USE A REALLY BIG SWITCH!
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click
click...
Chris-M
Re: Yes..
What? You have never heard of a transmit combiner?
Cavity or Hybrid???
Yes I have heard of a transmit combiner. I was just giving a simple answer to a simple question, which was how to RECEIVE on one antenna.
Thank you for the slap up' side the head.
:wink:
N
nmfire10
Guest
I think the cost of a transmit combiner for the basic scanner user would render it non-existant anyway :)
