Two tone decoder receiver.
Kingmobileaudio
Lincoln, NE
I have no idea if they even make this. A radio receiver that decodes two tones that you can hook up to a PC and have it send emails out with audio clips.
I have tried software with a scanner but the false trip rate is to high.
Sent from my HTC EVO 3D using Tapatalk
ramal121
Lots and lots of watts
Calif Whine Country
Never heard of a radio that will do that. There are plent of radios that will decode two-tone and will give you a logic signal to boot. Beyond that you'll have to hunt for software that could utilize the signal and do the appropriate processing.
rdale
Lansing, MI
Yes, any scanner is capable of doing that with software. Or you can use FTO on Uniden and just send out the audio.
Kingmobileaudio
Lincoln, NE
I know this and I have two 996XT. I am wanting to do a secondary paging system that sends out emails.
rdale
Lansing, MI
Sounds like you need a better quality signal in, or may e your tones are incorrect?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
If you just need a single channel receiver with Quick Call II capability, almost any alerting pager like the Minitors should work. You might need an attenuating patch cord between the pager and the PC. Minitors are all over Ebay and prices are dropping on the II's, III's, and IV's. The II's in particular are quite inexpensive now, and you can pick up a charger/amp cheap, too. The charger/amp is a good choice for your application because it has an antenna connection and an audio out connection. This guy refurbs Minitor II's and has a large stock of crystals and tone reeds: Home Page
The Veetronix receiver might be a good choice, too. Comm Products
Even a Plectron will work. This guy repairs, refurbishes, and sells them. Home
