Two Tone Horn Honk
LubeckTech
Parkersburg, WV
Is it possible to get a NX-5700 to activate it's horn relay (KAP 2 is present) when it gets a two tone analog page?
We can't find a way to get the radio to do anything but produce anything but an audio and LED alert.
kd4efm
EL98 Florida
What you need to do is set a button or menu item for HORN ALERT, press it to activate the horn alert function.
Set signaling for said channel, Optional Signaling 2-tone (or whatever) to activate the horn alert when the horn alert button is activated.
ramal121
Lots and lots of watts
Calif Whine Country
And this radio does not use a KAP2. Connection to 9 pin Molex on pins 4 and 5. Note current direction, high side on pin 4 low side on pin 5.
Arizona
If using in a FD station I always set it to start up rather than a button. Fire guys like to push buttons and not know what they do, thus the radio may not alert if they turn it off. A power failure can do the same thing if the button isn't activated again.
ramal121
Calif Whine Country
Probably just a typo in his reply and he meant to say 'this radio does use a KAP2', I can confirm that the NX5700 does indeed allow installation and use of the KAP-2 horn alert / P. A. relay.
You are correct for a mid power radio. I don't know why I thought a 5700HB but looking at the OP again I guess not.
