Two Tone Paging G5
Webodisk
Silent key.
Virginia Beach,VA
I have watched the video on the 2 tone paging setup, he only has a choice two tone , the newer software has a choice of two tone type 1 or two tone type 2, does this make any difference ? or does it depend on the system your are monitoring ?
TFrank615
Springfield, Ohio
Phase 2 , you use the system type to determine the setting ?
Sent from my iPhone using Tapatalk Pro
Yes, our system is Phase One right now so we use type 1. I was told if you’re Phase one then it doesn’t matter if you use Phase 1 or 2 however when I tested it tones on Phase two setting would not activate the pager. And for you if all else fails try both and see which one works
