I just set up my computer with ttd,, and i have all the tone sets in,, however,, in the "tone freq" the frequencies are around in the 60hz range. also my "audio level" is almost maxed out, the audio threshold is set just below 100 and the offset and tollerance are at about 2%. i have tried to squelch out the scanner to see if the frequency range changes, but it does not. shouldn't it be doing this? i am using a radio shack pro 450 scanner. I only have 3 frequencies programmed into the scanner.
I'm not sure what I'm doing wrong... I downloaded/istalled v24, it took some messing around with the ports to get my email to work... It works awesome, it detects just fine, records the audio, but for some reason, it doesn't appear to be attaching the audio file to the email.
I've tried using different email accounts (hotmail, gmail...), that didn't help. I also tried sending it to different email accounts (one is my personal email account, another was my cellphone), still no audio file attached. Can anyone help me out?
Thanks much! If I could get that to work...this program would be PERFECT!
magna131 check your pm inbox
I am trying to use TwoToneDetect with a Zetron .75/.25 system.
I am having difficulty getting it to recognize the B tone.
Also, my jurisdiction uses a warble (1500/800). Will TTD pick that up?
