Hi there,
First of all, great software! Thank you for creating it!
I have installed the software and am using gmail as my smtp. When I generate the appropriate tones, I get an e-mail but no wav attachment. When I put lame.exe in the data directory, however, I get an mp3 attachment. Unfortunately, I need the wav because my blackberry won't accept mp3's (long story -- see many frustrated blackberry threads online).
Just to double check, I checked my GMail sent items and the blank e-mails with just the appropriate subject lines are all that appears to be sent. Can anyone think of why it's not sending off the wav's (which I can see have been created in the /data/audio directory) but will send mp3's if lame is installed?
Thank you!!
I'm getting the same result here. I think you've found a bug. This probably cropped up after I changed where the audio files are stored. I probably didn't check the .wav file functionality after I made the change since I've only been using mp3 files. My bad...I'll get it fixed and let you know when the corrected version is available.
Andy
