Thought I'd try Andy's RPI image today, and ran into the same issue as everyone else (Will not boot). So I figured I could play around a bit to see if I can get it started. As of right now I can get it to boot and I am able to SSH in and see that everything appears to be working on my B+. I am still working to confirm that TTD and Darkice work for me.
How i got it to boot required me to download and image an sd card with the Current Raspian OS. Since I use windows I can only see the FAT portion of the SD Card. I believe this is the boot sector, I copied its entire contents to my windows machine. Then proceed to reimage the sd card with Andy's img. Once this completed I deleted the FAT portion contents and replaced it with the content I copied earlier. This got it to boot. I then noticed it wasn't detecting my sound cards so to get this working I had to use sudo apt-get install rpi-update, then sudo rpi-update, once this was completed and rebooted I finally did a sudo apt-get update.
My Sound cards are finally being detected, I am now going through and setting up TTD to see if it works!
