TX error on NX-700 device
HB9NF
Zurich
Hi there...
I've got some strange Problem. I've got an NX-700-E device, programmed with KPG-111D V.2.9. I've programmed no specialities and feautures. Just a simple simplex Frequency like 145.500Mhz analog an with 5k bandwith.
So lets have look at the Error:
If i power the device on everything is normal like on my NX-800-E. But if i push the PTT Button on my Handmike the device shutdown and start again. My Powersource has a power capacaty of 40A so that couldnt be the Problem. Ive tested multiple kinds of antennas with 50 Ohms and a big dummy load. So where can be the Problem?
Tnx for reply =)
Pat
Have you tried any other frequency besides a 2 meter frequency? If you have not try it, something like 155 or 160.
Are you using the supplied wiring harness from kenwood?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
I am a lineman for the county.
Check the power supply voltage. Even though it sounds like you have a large power supply, if the voltage is low, it can do what you are describing. Also, make sure you don't have any faulty connections. Loose crimps or other bad connections will cause these sorts of failures.
rg65
Where is your antenna mounted? I have seen VHF radios cause issues with cheap power supplies when the get a large dose of VHF rf.
Try a dummy load.
Sent from my iPad using Tapatalk HD
HB9NF
Zurich
Dummy Load / Other Frequency
Well i tried a dummy load as well and i programmed also some other frequencies. But it doesent work... All Connections are well and all cables are originaly from Kenwood. =(
Are you sure the PS has good voltage? Do you have a multimeter to check? Do you have another power source to check it on as well 15A should do.
