Tx inhibit on Busy?
beaker7
Boise, ID
I have a XTS 5000 and I would like to make it so I can't transmit on Rx (so we dont talk over each other) I know how to do it on my HT1000 but I cant seam to get it to work on my XTS 5000. I have MDC1200 enabled and have "Tx Inhibit on Busy" box checked under mdc1200. Any ideas?
gatekeep
FAIL 01/93
New York, NY
If this is a conventional personality:
Look for the Smart PTT tab under the Conventional Personality settings; and change the mode to Inhibit on Carrier. Additionally, if you don't want the user to be able to quick key override (i.e. double-tap the PTT to transmit anyway), make sure the "Quick Key Override" checkbox is not checked.
beaker7
Boise, ID
Ok thank you very much for that information!
beaker7
Boise, ID
Ok as it turns out the Tx inhibit on busy isnt working on my HT1000 and there isnt a smart ptt tab for the ht1000. any ideas?
beaker7
Boise, ID
Why are you using MDC? Do you have an operational NEED for MDC?
I'm asking because if you don't need MDC, don't use it. NOBODY wants to hear those data bursts!
Not using it also simplifies the configuration.
Were all using MDC1200 so all we hear is a little beep. If your eavesdropping and you don't like the data burst tough cookies.
cmdrwill
So Cali
BUT the dammed MDC is louder than all the voices.....................
Even with DOS enabled.
cmdrwill
So Cali
DOS does not have a 'beep'.
DOS is Data Operated Squelch............. mutes the MDC 'tones' on the radio's receive.
gatekeep
FAIL 01/93
New York, NY
Not on my radio, replaces the screetch sound with a beep. and I all ready know what DOS stand for.
FYI -- what sounds like a beep -- is likely not a beep -- its the beginning of the MDC data packet which the radio identifies and immediately mutes. The DOS muting happens fast enough that all you hear is the beginning of the burst which makes it appear to be a "beep".
If it is indeed an actual beep, you have some special firmware that the rest of us have never seen.
The only other beep associated with MDC and other analog signalling formats; was the Side Tones, those are synthesized beeps for the end user to know when he/she can speak.
