Tx problem with XTS3k
FFJeffro
Henrico, VA
This maybe be a topic well covered before but... In the past few days my 3k model 1 403-470 transmits but no voice is heard, it keys the repeater but nothing comes across... I have had bad mic's on other radios (actually not long ago...not same radio tho) so I hooked up the speaker mic and nothing the same thing no voice. Can someone give me some ideas what is wrong so I know what direction to go with this.
Thanks Jeff
Mr_Observer
If you have a speaker mic you can use it to verify a problem with a potential bad mic. If the radio works with a speaker mic the problem is in the radios internal mic or audio circuitry.
mm
oregon
He already tried the speaker mic and no go which leads to a failure in the radio or the more common problem an unseated connector.
The internal mic and the external speaker mic both connect thru the front case flex cable to the controller board.
If the front case connector going to the controller board is slightly off or unseated on one side it can cause this failure.
if you know how to remove the case, and you have the correct removal tool or you could just use a screwdriver if in a hurry, then you can re-seat the connector yourself.
Mike
FFJeffro
Henrico, VA
Well sorry that I haven't done it sooner but... I took the case off tonite and checked the connector. It was on fine so I pushed it down and all, nothing. Still no voice when the radio transmits, still keys the repeater and everything.
Any more ideas???
Thanks Jeff
XTS3000
Could be the DPS board gone bad. All TX - analog or P25 is feed through the DSP processor.
