Good morning, I'm using my SDS200. I want to add The Memorial Life Flight Heli, They are listed as part of the TxWarn system.
Its in the Air Medical section. When I right click to append to one of my Favorites, it copies this Entire Tx Warn .
I can then click on each one and remove, to eliminate the ones I'm not interested in, Question:
Do I need to use the Simulcast ? There are several to choose from.
My goal is to only scan what i'm interested in.
thanks
Dave
In Sentinel, you can select a single department, in a trunked system, to append to a Favorites list. That appears to be what you did. But the database does not contain information as to which talkgroups are active on specific sites. Since Sentinel cannot determine which site you need, it appends all of the TxWARN sites.
Obviously, a lot of them will be out of range for you. My guess is that Life Flight would not use the various Houston Public Safety sites. Hopefully, someone in your area can clarify which site (or sites) would be best. If no one answers here, you might try joining, and posting on HoustonScan via Groups.io
For radio scanner enthusiasts in and around the Houston, Texas area. P osting of frequencies and certain *hot* channels when there is something big happening (use discretion).
groups.io
As far as the extra, unwanted, sites, there's three schools of thought. One is to just use location control, which will let the scanner ignore those sites out of range. I suspect, though, that would still leave you with a bunch of extra sites, with so many in use in Houston overlap in coverage area.
Another method would be to Avoid (lock out) the extras. But here again, you'd still need to figure out which ones are vital, and which are not.
What I generally do is simply remove the extra sites, once I know which I need, and which I don't. The more sites you include to be scanned, the slower your scanner will run through your favorites lists. Again, if you can get feedback from someone in the Houston Metro area, that would help tremendously. My guess (and only my guess, since I'm 250 miles away) would be to use one or more of the Harris County Simulcast sites.
