Been trying to figure out a Motorola SMR (851-866 MHz) system. Found a control channel, programmed it as a type II system with status bits turned on with CC-only in my BR330T, and did a search and store. Got a big list of 200 IDs.
Most are odd numbered (or even and not divisible by 16) and a few are true type II ids-per block. One block (5) is all true type II ids. One block (1) is not even used.
How do I know if the mixed blocks are type I or type II using status bits? I've read that you can't have both (type I and type II ids) in the same block. Would that confirm it's a type II block with status bits?
I've found 3 other systems the same way and the ids show up just like this system. Are status bits that common with these types of systems?
I'm going to try to figure out the fleetmap if the system is indeed a type I or type II hybrid.
