Don - I think you mean its about $215 for EACH
Mike, since you asked the same question on
my forum, and you stated you were thinking ahead to Nassau's new P25 system, I will copy/paste my
reply here:
Welcome to the scanner hobby.
No, you don't need a digital scanner for Suffolk, but you will need something that trunks Motorola. If you are looking at a used radio, make sure it will work on a Rebanded system.
Basically, Suffolk County needs to move the trunk system down 15mhz and not all Trunk scanners will work after the switch. There is some digital stuff on SCPD, but not much.
A digital scanner will be needed for Nassau when they move to their new trunk system. I have been monitoring that system for changes..
What type of scanner do you want? Mobile or base?? How much are you looking to spend?
If you wanted a digital mobile, the Uniden BC996XT is the newest model. I've setup a few of those for customers and they are great radios. The audio is a bit "tinny" though. An external speaker takes care of that.
GRE makes the PSR-600, which is the same as the Radioshack PRO-197.
If you go used, the Uniden BCD996T, and PRO-2096 are good choices. I prefer the Uniden Models.
Expect a new radio to cost over $400, used around $300.
