- Joined
- Feb 20, 2003
- Messages
- 905
I found serveral data channels during my search of the 400 MHz band and want to enter the systems in my TRX-1. How do I find out what flavor the trunksystem are?
You can check the Radio Reference database for the system, you can check the FCC license for emissions designator (unless military), try using DSD+ or Unitrunker, post the find in your state forum those are a couple suggestions.
What are the FCC licnese emission designators for the different control channel systems.You can check the Radio Reference database for the system, you can check the FCC license for emissions designator (unless military), try using DSD+ or Unitrunker, post the find in your state forum those are a couple suggestions.
You should be able to tell by listening but that takes experience. You have to know what the different formats sound like.I found serveral data channels during my search of the 400 MHz band and want to enter the systems in my TRX-1. How do I find out what flavor the trunksystem are?
These are not in the RR Database, but soon to be which need to be investigated. Thanks.You can check the Radio Reference database for the system, you can check the FCC license for emissions designator (unless military), try using DSD+ or Unitrunker, post the find in your state forum those are a couple suggestions.
That is nice infromation. Thanks.here's a good start, mind you it's not authoritative and it's several years old.
Is there a website that has different recordings of the CC?You should be able to tell by listening but that takes experience. You have to know what the different formats sound like.
Not all constant digital signals are trunked system control channels.
If you post the frequencies somebody can probably tell you.
If they are non-federal you can look up the frequencies in the FCC database and see who they are licensed to.
If you do search with your TRX-1 you have boxes you tick in the mode setup in the search menu for which system types you would like to receive. Tick all of them and your scanners display will tell you what system types it is.
You can enter the frequencies in tune mode, Fn+1, and then push the menu button and you can edit there for the different system types filters and the scanner will automaticly switch to the systems different modes and display it.
/Ubbe
I am new with the TRX-1, just learning. I will set the TRX-1 up. Thanks.If you do search with your TRX-1 you have boxes you tick in the mode setup in the search menu for which system types you would like to receive. Tick all of them and your scanners display will tell you what system types it is.
/Ubbe
There used to be several. I would check this one Signal Identification Wiki or do a search for digital mode sound samples.Is there a website that has different recordings of the CC?
thanks for the information.![]()
Emission Designator - The RadioReference Wiki
wiki.radioreference.com
400-420 is the Federal Government - won't be in the FCC
420-450 is generally Amateur Radio
450-512 is FCC licenses.
What specific Freq might be better, than saying 400 MHz - since that is over 200 MHz of spectrum with varying formats
450 - 512 business.400-420 is the Federal Government - won't be in the FCC
The scanner will record talkgroups. If you are looking to log talk groups there are two. Whistler Control Demo Software (which doesn't work that well) and the PC component of the TRX Android Suite, both are free and will save log files of all TGs heard.Are there programs that will work with the TRX-1 that will record the talkgroups?
What do you want to record? Decoded voice audio, raw audio (digital noise) or log talkgroup data?Are there programs that will work with the TRX-1 that will record the talkgroups?
Something like the SDS100 does in Discovery mode. Record voice and the talkgroup. I have IDTracker and Unitrunker. Something that I can just let run all day.What do you want to record? Decoded voice audio, raw audio (digital noise) or log talkgroup data?
