TYT 380 analog
hey
Lewes, Delaware
I have a TYT380 with some analog channels programmed into it my issue is every time it receives the analog transmission it has a bad squelch at end of the transmission. How do I fix that
dazey77
Your in the wrong forum I am afraid, this is the Hytera, you should be in budget&entry level transceivers.
I have never used a 380 but you would be looking for something along the lines of Squelch Tail Eliminate in the CPS but different manufacturers use different schemes to do this, so it may only work with other TYTs
