tyt 390 and zones
teufler
ST PETERS, MISSOURI
Is there a way to get the radio to boot up with a specific zone active rather than turn th e radio on, then activate zone selection and get to the frequency or channel I want. I am using CPS MD390 1.36 . i CAN NOT LOCATE a setting to make a partical zone the default on boot up zone.
buddrousa
NW Tenn
Not sure about the 390 but my 380's power back up in the last state (where they were when powered down)
teufler
ST PETERS, MISSOURI
yep my 390 does that too, Got confused because I kept reloading different code plug configurations and every time had to go back to zone selection to get to the channels I wanted. I can live with this but was looking for a way to set the defaults channels with the software, like what I do with about all other radio software.
buddrousa
NW Tenn
You could put the most used main zone as the first in programming and it would start first after programming.
jonwienke
More Info Coming Soon!
VA
When you load a new code plug, the first zone in the plug is your default, until you change zones in the radio menu.
teufler
ST PETERS, MISSOURI
Is there away to reorder the channels . With the baofeng dm-5r you can drag and drop channels to rearrange their order. Maybe the CPS software can do that but I have not tried. Also looking to print a list that shows channel order, CPS doers not have a print function. Only way I have found to print is using a screen grab utility to highlight, then print. Print was be nice to get a print ouit of all channel settings, the contact and the groups.
jonwienke
VA
The TYT CPS doesn't allow any kind of sorting anywhere. You either have to edit the codeplug with a 3rd-party software (not sure if it exists), or delete and start over.
