Just purchased new. Tried to set up an initial test.
I am able to transmit simplex. But when I use a repeater, the audio is not transmitting. Basically seems that CTCSS is not transmitting at the start of my transmission.
I have set the frequency, offset, tone, and set it to ENC.
The radio does key up the repeater when I release PTT. It seems that the CTCSS tone only transmits when I release the PTT Key.
I can hear myself on the reverse frequency.
I have tried the following to troubleshoot
Is there another menu setting I am missing? Everything on the radio is still set to factory settings.
Thank you
- I have tried multiple repeaters.
- I have tried manually inputting the settings as well as using the software
- I have reset the radio to factory
- I have tested with other radios
- I can hear myself on the reverse frequency so I know audio is going out
Thank you
