TYT MD-2017 Heads Up!
bndavis6
Mesa, Az
MD-2017 Speaker Mic
So I have both MD-390 and now the MD2017. I am hoping someone has found a good speaker mic that works with the connector or has someone identified the connector? Is it a Motorola connector?
Ben
KG7TTY
2 more things...
Your_account - you can use the Chrome Browser and enable the "Google Sheets" extension. It will allow to create and modify any excel spreadsheet.
As far as the antenna connector. They are for sale on eBay for $6.
ke6gcv
Somewhere, Northern CA
2.5 kHz Channel Stepping for Programming
I know the radio does 12.5/20/25 kHz for analog and 12.5 kHz for DMR. Does anyone know if the MD-2017 can do 2.5 kHz channel stepping for programming analog frequencies into memory?
I would like to set aside a zone/group as receive only but the frequencies are narrowbanded and need the 2.5 kHz stepping in order for successful programming.
CanesFan95
FL
What's the current bug status on this radio? Are there any fixes still in the works that we should wait for, or does this rig work right?
N4KVE
PALM BEACH, FLORIDA
Until they do something about the flimsy SMA connector, the radio is not ready yet for prime time. One local distributor is replacing the connector with a more rugged version before he sells it. Atlantic Technologies, in Melbourne Florida.
N4GIX
Hot Springs, AR
metro_skywarn
St. Louis, MO
random transmitting...
Hi!
I have 2 of these radios. Both act the same. Every once in a while the rig begins to transmit on its own. When I look over I see it is in transmit mode. Both rigs have up to date firmware and programming. It has done this even with older firmware and programming programs.Any suggestions, corrections? tnx, jb
Starman70
Starr, SC
Tyt md2017
Recently purchased this unit. Installed the program on my HP computer running windows 10.
Every time I try to read the radio, I get a square box with the info, "Invalid port #"
I read that there was a programming cable problem on early cables and manufacturer has corrected the problem. Is this problem being caused by the cable? If not how can I fix it?
radicalbill
Malta, NY
Is anyone working on a MD Tools for the 2017
Just wondering if there is anyone working on an updated firmware like they have for the MD - 380 ?
Maybe an alpha version ?
Bill
Phillipsc84
Fort Mill, SC
Buytwowayradio had a promotion. Enter a promo code and the thing was offered at 175.
I did get an email back this morning. Says the buttons are not activated out of the box. I read it out and they're indeed programmed. They are also honoring the price and issuing me a refund for the difference. At least the customer service is good.
Not to drag you back into a year old thread but did you ever get the buttons working or just get a return?
