Tytera TYT MD-380 Scan Question
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
Looking for help on MD-380 Priority scan. I have a Scan list created with 2 DMR channels. In the scan list menu i have Priority Channel 1 as Channel A and Tx Designated Channel set to "Channel A". When audio is coming through on channel 2, the radio is NOT reverting back to the Priority Channel A. In each Channel i have the "scan list" selected that was set up. Please let me know what i am doing wrong. Thank you
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
They are using DMR and both channels and just simplex, no repeater. Can you elaborate on the functionally of the Receive Group Feature?
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
With the TYT MD380 you can NOT utilize scan for DMR Channels that are fully "built out" with color code, etc. You would have to create an analog Group of just the repeater simplex freq.
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
Thank you. ok. So either revert back to analog programming OR utilize scan, but cannot take advantage of the priority channel features?
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
NOt sure about Priority but what I know for sure is that you can not scan DMR Channels that are fully built out in digital, analog-only.
I have an MD380.
hmm. ok. thank you for your input. However, I am able to scan in DMR with a color code, slot and talk group successfully (only tried simplex) . I programmed 4 portables and the radio definitely changed to the DMR channel when signal was received on that channel. I just could not get the priority revert channel to function properly when a 3 radio keyed up the priority channel. Thus, what you are sharing is that the radio is not built to function with full DMR features as originally thought. oh well.
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
make sure that in each & every channel you have to select the "the scan list" from the drop down as well. I ran into that on my 1st attempt with an unsuccessful scan.
Ubbe
Stockholm, Sweden
I have several scan lists with 24 channels and are a mix of analog and digital in the scan cycle and there's no problem to scan those, both TierII and III.
I believe the priority function only works when you are on an analog frequency as it would take too long to sync up again to a digital DMR transmission when it has finished sampling the prio channel for a carrier.
/Ubbe
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
/Ubbe
Bummer... wish the option to enable was then gray out when selecting. Dmr only. but yes... $80 versus $500 / radio for Xpr. ya get what you pay for. Thanks for all of the responses.
Medic10mda
Ø Pittsburgh, PA
Pittsburgh, PA
Yeah, I want an XPR7550 but the programming software and cable end up being more than the radio. Buddrousa am I wrong?
Software is around $200, aftermarket cable is $35.. but you have them as a fixed cost and can use for many years. Xpr...375 used to 600 new.
