Tytera TYT MD-UV390 Codeplug Issue
aaronjudze0806
Cleveland, TN
I cannot get my radio to receive any audio for any digital channel. Can someone please review my codeplug file and let me know what I'm doing wrong? My Baofeng DM-1801 works just fine, but I can't get this radio to receive any digital audio. I only get analog voice. It won't let me upload the file so let me know where I can send it. I'm in the Chattanooga, TN area.
N4VKF
SPOTSYLVANIA,VA
I may be able too. I have the UV380 gps version so I think the CPS might load your codeplug. Are you using a repeater or hotspot? also are the tg's dynamic or static?
aaronjudze0806
Cleveland, TN
I'm using a repeater. I don't know what you mean by dynamic or static. I unlocked the device per instructions on buy two way radio and the audio immediately started coming through. So maybe it was because it was locked? I do have one talkgroup that is not working. I'm using their frequency with no offset. It works on my Baofeng DM-1801 but I can't get the TG to work on my MD-UV390. Thoughts?
N4VKF
SPOTSYLVANIA,VA
Certain talkgroups are PTT activated and others are on full time. Yes so I suspect because the radio was locked. Same issue with my UV380 when I update things. Weird a repeater should have an offset.
aaronjudze0806
Cleveland, TN
Can you give me your email to send my codeplug file to? I don't know if I have this thing right or not.
N4VKF
SPOTSYLVANIA,VA
Usually the admit criteria is set to Color Code Free and the In Call criteria set yo Follow Admit Criteria. Also some of your channels appear to
be extra or duplicate that are not assigned to zones. Nothing in the code plug stands out to me as incorrect.
aaronjudze0806
Cleveland, TN
Thank you for looking at it. After a lot of messing around with the CPS and radio I finally figured out the issue. The MD-UV390 is much more difficult to program than the Baofeng DM-1801. With the Baofeng I only needed the one frequency and CC 1 to get the local Ambulance DMR to work. With the MD-UV390 I had to offset the frequency, change the CC to 13, and remove the Group List. It's odd to me how two radios have two completely different settings for the same DMR system. It works now so that's what counts. Now on to figuring another company out...
