Tytera TYT MD-UV390
k3pto
I just purchased a used UV390 from a friend. It seemed to be working for a while but now the transmit frequency is off by quite a bit: about 4MHz on 146 and about 8MHz on 440. The receive frequency may be off but I did not test it. Anyone know of a way to calibrate this thing?
Ubbe
Stockholm, Sweden
You can't calibrate 4Mhz and 8Mhz off in frequency. But you probably ment to say KHz. My TYT software for the MD380 has a service mode function where you can calibrate everything in the radio, including the frequency. It has to be the same with the UV390 but the program are missing from the TYT website so you have to get it from another source.
/Ubbe
