The Face with read out has two setting, dual mode and single mode. The radio beeps non stop in dual mode, when I switch to single mode Key2 shows on screen bottom middle. above the settings button and the beeping stops. I was playing with the radio earlier in the day, turned on cross band repeater mode tested it using my anytone HT, shortly after I started having problems with the non stop beeping. Searched the web on and off 18 hours and there is NOTHING about this issue listed. I can receive and transmit on either side in single mode, not sure about dual mode but I am guessing will transmit in dual mode but there is the beeping. I have reset the radio once, currently have 3 channels saved 2 repeaters and 1 winlink server. The manual honestly needs more work, I am thinking the beeping is from user error, something I turned on or off. does anyone have any ideas I can try to stop the beeping noise? New comet UHV-4 antenna arrives today and am hoping to get some 6 meter and 10 meter action going. Right now am connected to a max rad UHF VHF antenna set to work the 3 channels I currently have saved on radio.
73
KL5GI
73
KL5GI
