Tytera TYT TH-9800D MON button
N7TAK
Might not be the right forum, but here goes. On the UV8000D, it says that holding, then releasing the MON button will squelch the audio, so that if you want to hear an active station, you have to hold the MON button in. Anyone got a clue as to how to override it or kill it so as you spin the dial and pass an active station, you hear it?
alcahuete
Southern California
Might be the Chinglish in the manual, but what the monitor button should do is turn off the squelch, so you hear everything (even those stations that don't break the squelch). You should hear a bunch of static when you do that. If the station is strong enough to break the squelch, you will hear them. You don't need to push that button to hear other stations.
