Tytera TYT TH9800 Programming problem
KC1TEJ
Parkman Maine
i am trying to program my new tyt th 9800 but when i go on chirp to read the radio it says prolic not correct contact your supplier but i dont know what to do i need my radio to be programmed
AK9R
Staff member
Super Moderator
Central Indiana
Is it saying something about "Prolific"? That's a manufacturer of USB to RS232 chips. The message may be referring to a problem with your programming cable.
paulears
Lowestoft - UK
The cables are based on an old prolific brand chip, and some versions of windows now object to it! For a while, Windows spotted it and actually uninstalled the driver 'to protect you', then they seemed to not check and the latest update now gives you the warning message. If you google prolific usb cable driver - you'll find the old drivers and if you try installing these, it might just get you around the warning. My office computer though, just re-installs the windows one which is newer, and doesn't work.
For what it is worth, I really hate chirp for programming these radios - the manufacturers one has always worked better for me.
KJ5DQQ
Has anyone ran into a issue programming the hyper keys? I have no issue programming the "A,B,C,D,E,F" buttons on the main unit but I cannot seem to get them to work on the handheld speaker mic. Any ideas?
CAVUCO
Upstate, NY
I am having a problem with programming the hyper memory keys on a TYT TH-9800.
I have 20 freqs total in channel memory positions 1-20
The first ten I want to be scannable and the second ten selectable but not scannable (skip). I want to place that config in Hyper Memory A.
I am using the software from TYT to do this. I save the DB to the computer and also write it to the 9800. Once installed, I press and hold the Hyper Memory A button for 2 seconds (until it beeps).
I then go back into the software and change the scan feature on the first twn to skip and the second ten to scannable. and write this to the 9800 and press B until it beeps.
No matter if I short press press A or B (to retrieve the configuration) after that, the same group of freqs is scanned (the last configuration written to the 9800)
This is different than the FT8900.
I can't make heads or tails from the written manual.
Any help would be appreciated.
KK4HAM
Ocala, FL USA
The microphone doesn't have that ability. The hyper keys only work from the faceplate.
CAVUCO
Upstate, NY
