Tytera TYT/Tytera MD380 DMR HT
Voyager
Another option is to set multiple Scan Lists - one per per channel and have that channel removed from the scan list (make sure SELECTED CHANNEL is removed, too). Basically, it will be a current cc selector which removed that channel from scan.
I have about 35 zones currently. Assuming 10 channels per zone, using zones to select the cc would be about 350 zones.
Of course, the only thing the cc does is slow the scan slightly. You can just scan all the slots with an additional couple hundred mS on the scan time. It's not like it's a necessity to remove it. Scanning TS2 of that LCN causes the same effect anyway.
Pippo1973
Hi Guys, please I need your help for this radio.
I bought it (uhf version) some weeks ago. My idea was to test its DMR listening capability and comparing iT to DSD software
I programmed IT using the proper cable and the software. Analog channels work fine: I can listen analog repeaters without problems. I'm having issues with digital features: if I speak in DMR mode, DSD can decode my voice (so the radio seems to be ok). But If I listen to DMR repeater (the frequency was properly set), the radio led indicator becomes green but no voice is heard from speaker (also pressing monitor button, and opening squelch). At the same time DSD decodes repeater DMR activity with no problem
Which are the mandatory parameters to set, to listen-only DMR communications? My aim is only to listen (aor d300/ dv1 are too expensive), but I don't understand if I have to set other parameters for such activity or my unit is faulty.
Thanks for you help
R
K4APR
Chesapeake, VA.
Now that the MD-380 has been out a while, is it still a good option? Did they make improvements to the firmware? I'm a little late to the party, but still interested in picking a couple of these up for when my club goes full DMR/analog mixed mode on our Motorola XPR8400 repeater.
N4KVE
PALM BEACH, FLORIDA
They are a decent radio, & are about $165 which includes the prog cable. They are constantly upgrading the FW on them to make improvements, but remember most of the low budget Chinese DMR radios use the same company in China to write the CPS. So they share the same bugs. Eg the CS700 does not do T/A on a repeater freq. Also, while a signal is being received, the radio can not enter the "menu" mode. You must wait until the carrier drops, or change to an unused freq. The MD 380 shares these exact same bugs. But for the $, if you can deal with these bugs, the radios are a good value. Of course, Moto, & Hytera radios do not have these bugs.
Arkansas
The cs750 will do talk around on a repeater channel and you can enter the menu mode while receiving a transmission. In my opinion, for around $100 more its a better radio.
N4KVE
PALM BEACH, FLORIDA
Good to know the 750 fixed the shortcomings of the 700. But a different company is writing the CPS for the 750 vs the 700, Tytera, Anytone, etc which are all written by the same company. I recently got a new XPR3500 for $350. That's a GREAT radio.
N8OHU
And Motorola has been doing DMR for how long compared to these other companies? I'm sure they had their share of issues in the beginning, and still do, or have you forgotten the AGC debacle that still hasn't been completely fixed properly from what I understand.
Voyager
Assuming you have the frequency correct (and you should since you see the green light), you also need the following:
1. You need the SLOT programmed. You may need to program two channels - one for each slot.
2. On both of these channels, you need the RX Group programmed. That is a list of the TGs you want to hear. You set the group in the channel options, and in the group you set all the TGIDs. You also will need to set those contacts in the Digital Contacts.
Note: The exact terms may be slightly different. TYT is my third language (Motorola and CSI are my first two).
I think that covers everything you absolutely need.
Pippo1973
Thanks a lot Voyager! I'll try it soon.
Honestly I thought that DMR listen activity was simple as Dstar (just switch on the radio on the channel, select digital mode and go )...my fault :)
Thanks again
Best Regards
R
R.
R
fjl43
Connecticut
Using a Mirage Vhf/Uhf Analog Amplifier
I am considering buying a MD380 DMR Handheld. I need to hit DMR repeaters 40 to 50 miles away.
Can I use my Mirage dual band amplifier, 35 watts uhf with the MD380 to hit these repeaters. I have a high gain 6 db vhf, 8 db uhf antenna mounted about 20 ft. above ground level.
Regards,
W1POP
N4KVE
PALM BEACH, FLORIDA
No. Because of the way that DMR works with 2 timeslots, the amp can not switch quick enough. You would need a DMR specific amplifier which are available for commercial use, but cost a fortune.
MrMushroom
Michigan
MD-390 code plug for Mi
MD 380 sorry .Just getting into dmr and was wondering if anybody has the code plug for Detroit, Michigan area
RayAir
Just a note, portable performance is pretty bad on that system. Their web page boasts good coverage. I haven't experienced it.
I've used an XPR 6550, MD380, and CS700 on that system and there is no coverage down I-75 in most parts of Oakland Co.
kevino
Database Administrator
Chicagoland
MD-380 for $130 through CSI?
Not trying to hijack the thread, but I figured I would share. Good deal on the UHF model only with programming cable. Check it out on the link posted below...
MD380U - Digital
I would give them a call to see if that's the actual price or not. I Googled "Connect Systems" and went to their site that way. I found the price to be $165 there. The link that "johnls" posted has the word "demo" in it. A few months ago, Jerry asked members of his CS7000 Yahoo Group to take a look at a mock-up web page that he was thinking about switching to. Maybe this is one of those pages? On a positive note, that "demo" page does allow you to put it in an online basket and you can go to a check-out page that shows the $130 MD-380 ready for purchase. Hmmm....
johnls7424
Somewhere in NJ
Yeah on the website it's " iffy" cause they have it posted at its regular price their offering for 165. However, like you stated it has " demo" versions for 130 plus shipping costs. Others have raved on Facebook about its price and have received their radios and stated only success with it. However I've never purchased radios through them. Only private sales, HQ98, and buytwowayradios. So, I do not know their turn around rates with shipping and support coverage. Though for 130 plus shipping cost isn't too bad, demo or not as long as the support is offered. Also want to know why they say " demo" radios in their sales pitch. Are they refurbished radios or returned items? Or simply are they extra demo radios from over a year ago when they came out? Guess I just have some unanswered questions and concerns about it being so low that's all. Maybe someone would like to chime in on their experience with the company and this particular deal that's going on?
rescue161
KE4FHH
Hubert, NC
The price still shows $165 on their site, but when you go to the "Buy Products Online" and select the MD-380, it shows $130. It's real, but it is for a limited time.
