TYT UV380 DMR programming help
NS9710
Petersburg, VA
How do I program a DMR frequency like the Petersburg, VA School Buses, Southpark Mall in Colonial Heights as a RX only in a TYT UV380? Thanks
NS9710
Petersburg, VA
Does the Contact name have to be specific or can I name the contact whatever as long as I have the correct number for the talkgroup?
Enter the data on a channel sheet, disabling the transmit function. Add the channel to a zone list.
Ghstwolf62
Clifton Forge Virginia
TG is what is important. Keep in mind as far as I know you can't have to of the same TGs in the CPS. So if one place has TG 1000 and you find another with 1000 as well you can't have two entries with that talk group number. You can use the same contact for both and receive fine but the name would be the same on your display.
