michaelcamilo
Hello!
I recently acquired the chinese TYT UV3R and am enjoying the radio. I switched the stock antenna for a Diamond SRH519 whip. Often, when I get in the car I will unscrew the rubber duck or the whip and switch over to my mag mount.
Unfortunately I must have screwed it on a little too tight. The sma connector base actually unscrewed from the chassis itself. The base of the element is copper and I can see silver discoloration where it appears to have been soldered to the radio. It is easy enough to screw the sma base back onto the radio and I seem to be getting a good RX signal. TX works on close range simplex but I am not hitting local repeaters very well.
After taking the radio apart, I cannot figure out how one would resolder the connection as the sma antenna base screws in through a hole in the chassis but the solder point is completely inaccessible.
Anyone have experience with this?
