U/Aware: U/Aware on Laptop
DewAddict
Michigan
Good morning all,
Just wanted to share this for anyone that uses a Motorola cell phone that supports their "Smart Connect" app. You can connect your phone wired or wirelessly to your laptop and mirror the apps to your laptop including the audio. I use this while working and have full control of the scanner with audio coming from my laptop. You can resize the app window to your liking so you have room to have your other apps on the screen. And you get a volume control on the screen mirror or you can use Windows volume mixer to set it to your liking. Screenshot attached for reference.
AB5ID
Lee's Summit, MO (Kansas City)
I don’t use U/Aware, but you should also be able to use BlueStacks. It is an Android emulator that lets you run Android apps on your PC. Once installed, you can access the Google Play Store.
DewAddict
Michigan
Bluestacks was my first thought too but last I checked it does not support apps that require bluetooth connections according to my research.
