- Joined
- May 2, 2008
- Messages
- 51
Hey guys, I currently decided to download the UASD Demo for by BCT15 becouse I wanted to re-program the scanner do to moving to a different location instead of programing all through the head of the scanner. I downloaded the information from the scanner to the UASD and saved it to the database and +\- some frequencies. The problem that I'm having is when I want to write to the scanner, a window pops up that reads (Only systems named "Conventional","Motorola","EDACS","LTR" are written to the scanner.) OK. When I press (Select All) since I have only one system, then I select (Write), a message pops up that says all the intormation will be deleted. I pressed OK since I saved the system to the database after I made some adjusments. After its done writing, the scanner says that thiers nothing to scan and my system is no longer it in.
Am I doing something wrong in UASD, or is Uniden pulling a fast-one since they want you to buy UASD. I dont know the reason why the program has to delete the information before it writes to the scanner. Any information on this matter would be appreciated (I really don't want to spend the $30, but I will if I have to).
Renze8173
Renze8173
