uasd help
frank125
hello while trying to backup my system for the 996t it keeps showing communications error! please check uasd remote settings. please any help with this. thanks in advance
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You would be far better off using Freescan - in any case, there's nowhere near enough information here. What OS are you using, which USB cable, did you load the most up to date drivers, did you check Device Manager to see what COM port you've been allocated...
It's very important to load your drivers and get the USB cable setup FIRST before connecting the scanner and software 73 Mike
