Hi
I have bought a used Uniden UBC 780HLT Trunktracker III with an aerial(not the orriginal
icture attached).
I cannot get any brodcasts except the channels I would pick up on a normal FM radio. This is VHF from 87.5 to 108.0 MHz.
If I press the SRCH button it seems to go through the frequency range OK and does stop on some frequencies but I only get noise.
I've tried it with the squelch from high to low.
I don't know if its the areial or the scanner or how to check if these are working OK. Or maybe my location which is UK, Essex. Basildon.
I am scanning in a two story building from the second floor, with the aerial in the same room as high as I can get it,.
As you may have gathered, I'm new to this and would be greatfull for any help.
I have attached a picture of the areial and the scanner.
The aerial has seven bars attached midway up the center pointing down and out at an angle. There is one missing ie. should be eight in total.
There is no makers mark that I can see and the base is magnetic.
Regards
Eamonn58
Regards
Eamonn58
