UBCD536-PT Sentinel
newcastlescan
Maryland NSW Australia
Howdy All
I have received a Uniden UBCD536-PT with a blank SD card
So far i have been unable to find the correct Sentinel version that would be on the SD card, and firmware updates to resurrect the unit to make it operation..
any help would be appreciated as all I can get is a SD Card file Error
this is a Australian release
Cheers
Mike
Newcastle's premier scanning website since 2001
As Usual i have purchased Butel software but no luck there yet
HogDriver
Blackford Co. Indiana
I believe if you "Clear User Data" that will also format the card while it's plugged into your computer.
ofd8001
Louisville, KY
"Clearing User Data" removes and replaces only those files associated with the scanner. It does not do a format of the entire SD card. So if you have an SD card that isn't formatted in the correct way, Sentinel won't correct it to a format it will recognize.
To do a full formate of the SD card, Uniden has previously recommended SD Formatter https://www.sdcard.org/downloads/formatter_4/
gary123
I strongly recommend having a saper SD card programmed for the scanner. They are small and if you need it its invaluable.
VK3RX
Thaumaturge
Australia
I believe the version of Sentinel is different for the Australian UBCDx36PT models because they have different firmware from the U.S. BCDx36HP models.
If no luck with Pacific Telecommunications Pacific Telecommunications you could try a post on AURFSCAN.
rustynswrail
With the scanner turned off, hold down the 2, 9 and CHANnel keys then turn it on. See if that helps. If not then ask on an AUSTRALIAN forum you will probably do better.
R
