UCI + Medical Center
ertony
Anyome know whats up wih UCI's trunked system? Im sitting IN the medical center in orange and have checked all 3 control channels and there is absolutely ZERO noise... Did they change from their trunked system? whats going on??
LAflyer
Global DB Admin
Moderator
SoCal
I believe either the TRS system listed in the DB has additional frequencies, or the university has a second system running as well.
Take a listen to:
852.0375
854.6375
855.7375
855.9625
Also there are a host of non 800-mhz frequencies licensed on campus per FCC.
151.655
154.515
452.0
462.1125
463.3375
463.8125
463.9625
Submit your findings so that we can update the Db please
ertony
thanks for the info! ill check those out. im actually not interested in the campus as much as i am the medical center (where i work). i live near the campus and can now verify the TRS is up and running fine. im assuming the TRS is no longer used at the medical center because NO control channels have activity... so either they went back to conventional freqs or a different TRS.
*sigh*
Take a listen to:
852.0375
854.6375
855.7375
855.9625
151.655
154.515
452.0
462.1125
463.3375
463.8125
463.9625
LAflyer
Global DB Admin
Moderator
SoCal
I managed to catch some activity on 855.7375 DPL223. Mention of an inop elevator, and also to meet someone at the emergency entrance.
I'm too far away to monitor regularly, but suggest you give those 800mhz frequencies I listed above a try as there might indeed be life in them.
Kindly report your findings with a submittal to the Db.
Mick
Western U.S.
These should still be in use at the Medical Center:
855.7375 D223 UCI PD "Blue"
855.9625 D466 UCI PD "Green"
ertony
thanks mick. I have caught some activity on both of those. Any chance you know what either is used for? I am almost getting the sense that I am hearing the same voices/units on both channels within minutes of each other. Could it possibl be trunked? Odd...
Mick
Western U.S.
For this listing, UCI = Univ, Calif. Irvine, and PD = Police Dept. A frq with a DCS tone is not part of a TRS. These are conventional channels.
