UHF Repeater Antenna Spacing Question
cmdrwill
So Cali
Is fred daniel the same Fred from sunset?
If so, he is considered one of the experts in his field.
I have not seen him since the late 70's early 80's.
prcguy
Its not that easy, the coupling loop inside the cavity is part of the equation and affects the needed cable length. If you call most mfrs and request such a cable they will tell you its selected during testing and tuning and they can't quote a length without you sending in your filter(s) to be fitted with the interconnect cable.
prcguy
Depends. You would need to calculate the 1/4 wave length at your frequency, then adjust it for the coax jumper velocity factor, then multiply by 1, 3, 5, 7 or 9 depending on how long you need it.
