stormtracker78
Hi I have a quick question for you antenna experts out there I have a tram 1411 receive only discone antenna I just got the bearcat 992 P2 and I have a whistler 1065 I was going to run some ABR 218x equal to LMR 240 to a UHF t connector and then two jumpers from that with BNC connections on one end into the two scanners the antenna will be about 30 ft high give or take with about 75 ft of coax but upon doing research I found out that supposedly UHF is a brick house after about 400 or 500 MHz and signal reception drastically goes down however I have not been able to determine is that in transmission only or in receive only the stridesburg unit would be great but it's 200 bucks almost a pop so I'm trying to find a more economical way for a duplexer I do not mind sacrificing one signal bar but if it does lack in receive drasticaly through the UHF connectors how much so percentage wise will I be giving up versus getting that stridesburg also I've been considering getting some j poles for the airband and railway band but I'm not sure how the copper soldering holds out in high winds as I live in South Texas I'm thinking maybe I can put epoxy around the soldered connections but if anyone has any j poles and experience with that please let me know thank you all so much for your time
