UID Folder for XT Scanners
alphaacres
Oswego, New York
Could a UID editor folder be added to the firmware of these scanners
Then there would be a UID editor for labeling UIDs
you can make this happen by labeling a group folder UID Put UID numbers where the talk groups go and write the alpha tags but this does not let any UID numbers show only the ones you UID tag
ofd8001
Louisville, KY
I'm not completely sure of what you are talking about. . .
I use ARC XT Pro for programming my XT Scanners. What I've done is create a separate group in which I only have Units IDs. In that group I put the Unit ID Numbers (preceded by a lower case i) in the Talkgroups column. In the Alpha Tag column I put a description of what it is, for example "Engine 1".
If the scanner is receiving a transmission from a radio that has had its Unit ID number programmed, then the Alpha Tag is displayed on the scanner. Otherwise just the Radio ID number is displayed.
