UIDs
Syncopations
Hears voices in my head.
South Texas
On random occasions, a radio ID of 16363 keys up on any given talk group on an EDACS system. When it happens, all I hear is a loud buzz, like a radio denial sound. My question is, is there any way to block or "Avoid" that particular radio ID?
Thanks.
troymail
Silent Key
Don't believe that is possible --
Curious - are other radios on the same TGID normal/clear? I wonder if it's some type of one-sided encryption and/or use of ProVoice....
Syncopations
South Texas
All radios are in the clear. And all of the radio IDs used on the entire system are in the 6000s and 7000s. It's an analog system, with some ProVoice. I have the ProVoice and DMR upgrades so that wouldn't be a problem.
It sounds like a desync issue or something.
It happens sometimes after a unit releases the key or after a patched talk group.
nd5y
Wichita Falls, TX
I had something similar happen with the local EDACS ProVoice system and BCD396T.
There was one radio ID that whenever it keyed up on a certain encrypted talkgroup I would be blasted with raw digital audio noise. It was obviously a bug in the firmware.
Syncopations
South Texas
I had the same thing or a similar problem with the local encrypted EDACS ProVoice system and BCD396T.
There was one radio ID that whenever it keyed up on a certain talkgroup I would be blasted with raw digital audio noise. It was obviously a bug in the firmware.
When I monitor the same system with my Harris P7100 or P7200 radio, or even with the Orion Mobile radio, I don't hear that noise. Like I said, it's random. I could go hours or days without hearing it. It's just a strange anomaly.
nd5y
Wichita Falls, TX
I forgot that whenever it happened the 396 would display it as an iCall with that particular radio ID.
tglendye
Blue Ridge Mountains, Shenandoah River- VA
That's cool. I've never seen an iCall on my x36 for any system, and I didn't know if it would follow it on a ProVoice system. Thanks for the information.
KE5MC
Lewisville, TX
Thanks.
If using ID scan would it not be possible to add ID of 16363 and then specifically select AVIOD for that ID?
Mike
KE5MC
Lewisville, TX
I read radio ID and did not comprehend it.
On second thought my suggestion not applicable to ID scan as that number would not be in the list anyway and would not stop scanning for it.
Engage brain before starting fingers. :D
Mike
nd5y
Wichita Falls, TX
The 396T does not follow anything on ProVoice.
Normally it totally ignores all ProVoice activity whether it is encrypted or not.
This is a software bug that only occurs with one particular RID/TGID combination.
jonwienke
More Info Coming Soon!
VA
In digital systems, both talkgroups and radios have unique IDs.
You can scan for or Avoid a talkgroup ID, but not a radio ID.
ofd8001
Louisville, KY
I can't find anything anywhere to set an Avoid based on a Radio's Unit ID. I can see where having that may create more problems than it solves.
bama9999
Gulf Coast
tglendye was talking about the x36 model of radio, and nd5y was talking about a 396T. So, in response to tglendye's post, I have a 536 and monitor an EDACS system with ProVoice, and it follows icalls just fine.
