(UK) FM Radio faces Government switch-off as Digital listening passes 50% milestone
GW7MGW
Llanfair Caereinion, Mid Wales
As yet I still have to switch to F3E to get radio reception in the hills of Wales, with FM the signal starts to break up a bit, but you can still get reception, with DAB it simply cuts out, all or nothing.
I really don't understand why we have DAB, all the programs are also broadcast on Freeview so all we needed was a Freeview receiver for sound only there was simply no need to have yet another frequency for commercial broadcast radio.
Although Roberts do a solar powered DAB radio because the DAB receiver is so power hungry solar powered DAB radios are rare. As to clockwork I can't find a single clockwork DAB radio, loads of FM clockwork, but not one DAB.
I remember MW and LW AM radios where all you needed was a high impedance ear piece, a diode and a coil of wire around a discarded toilet role, a variable capacitor allowed fine tuning, not a battery in sight.
From that point each "advance" seems to need more power, for safety information like weather reports you want a radio that uses very little power so batteries are small and last a long time. I found one with a 700 mAh battery that says charging time 3-4 hours and play time up to 10 hours, however it does not say if this 10 hours is FM or DAB, my Baofeng UV-B6 radio will allow me to listen to FM broadcast radio, it lasts for a long time listening and the same unit can transmit to call for help. It is small and easy to carry when walking in the hills, and cheap to buy, around £25 and is now part of my safety equipment.
Show me a portable light cheap transceiver with DAB listening ability which one could carry to both listen to weather reports and if necessary call for help.
Pete_uk
Gloucestershire, England
What annoys me sometimes is the rubbish coverage some transmitters have. Crank up the power! Its 220mhz, where you could pick up TV from 50 miles away with a pair of scissors!
