I have not used LMR-400 UF, but I have used LMR-600, LMR-400, LMR-240, LMR-240 UF, LMR-195, and LMR-195 UF in my own personal use.
Ultraflex of any size coax has 2 disadvantages, you give up more signal, and you give up more money.
It has the advantage of being more flexible than it's standard counterpart, which sometimes is needed.
As prcguy said, if you need that flexibility for your install, then get it.
If you go to the manufacture's website you can get specs for the minimum bend radius for all of their different cables, for instance here is Standard LMR-400,
This calculator is also very helpful in determining what size cable you need,
Calculate the attenuation and power handling capability of coaxial cables using the online calculator by Times Microwave Systems. Choose from a variety of cables and get started now!
www.timesmicrowave.com
If you let us know the length of your run and the frequencies that you plan to monitor we can also help with a suggestion.
