Un-prompted transmit
REMYXC3V3
Hello,
I have a strange question / experiment. I'm wondering if a PD78X (or any hytera) ever transmits without explicitly being prompted. If it doesn't ever transmit without explicit signaling instructions, other than lone worker (which is configured to transmit based on several parameters) and roaming (pinging new towers), where else could you configure a hytera in the CPS to silently transmit as maybe a beacon or distress signal?
Basically is it possible to use one radio to tell another radio to key up without physically "pushing to talk"?
Thanks!
dazey77
deleted- didn't read the full post!
If you turn on some of the emergency or data systems they do ping a repeater periodically but I dont think thats what your after
n1das
Nashua, NH
A digital channel can be programmed to periodically transmit GPS data.
Sent from my Nexus 6 using Tapatalk
REMYXC3V3
Forgot to mention: Not GPS capable.
Does anyone know if a PD would ping an RD before the PD tries to make a call if it is roaming and picked up a stronger signal from a new repeater?
n1das
Nashua, NH
Sounds like you have a PD782 instead of a PD782G. (G=GPS)
Dunno about pinging during roaming.
