Unable to connect remote server
jonwienke
More Info Coming Soon!
VA
tracert is similar to ping, but it shows each device the packet passes through on its way to the destination. So if you can't connect, it can give you an idea of whether the problem is in your router or your ISP. This shows a successful trace:
C:\Users\jonwi>tracert ftp.homepatrol.com
Tracing route to ftp.homepatrol.com [69.15.51.147]
over a maximum of 30 hops:
1 3 ms 3 ms 12 ms 10.0.0.1
2 41 ms 54 ms 45 ms 96.120.9.209
3 16 ms 63 ms 24 ms te-0-0-0-11-sur02.chambersburg.pa.pitt.comcast.net [162.151.68.165]
4 42 ms 15 ms 83 ms be-8-ar01.lancaster.pa.pitt.comcast.net [69.139.194.53]
5 90 ms 23 ms 26 ms be-34-ar01.mckeesport.pa.pitt.comcast.net [69.139.168.141]
6 74 ms 28 ms 69 ms 4.68.71.133
7 168 ms 100 ms 101 ms ae-3-5.edge5.Dallas3.Level3.net [4.69.208.229]
8 114 ms 91 ms 61 ms CBEYOND-COM.edge5.Dallas3.Level3.net [4.71.120.114]
9 * * * Request timed out.
10 * * * Request timed out.
11 70 ms 108 ms 94 ms mail.dcius.com [69.15.51.147]
Trace complete.
C:\Users\jonwi>
Line 1 is my router.
Line 2 is the ISP device it connects to.
Lines 3-8 are various devices the data travels through on its way.
Lines 9 and 10 block pings and so they didn't respond.
Line 11 is the destination IP address, which apparently has multiple domain registrations.
If there is a blockage, the trace will fail before it gets to the destination. Where it fails will tell you where the problem is.
clutchdisk
Jackson Springs, NC 27281
Thank you all. After all reinstalls of win 10 and sentinel. Checking all settings and changing settings. I finally went to the router. This was the last ditch effort. Found one setting on the ubee router firewall set to high. Well didn't set medium went and changed directly to low. Used traceroute pinged the ftp site no time outs and had positive results. The end game was to install sentinel. And low and behold the sentinel worked like a champ ! If it wasn't for this forum I wouldn't have known where to start. Was a pretty long road but worth it in the end. Learned a lot. By morning I'll probably forgot. In the end didn't have to uninstall a bit of software. Better I shut up now before I hit the delete key by mistake !
